I'm getting a "zero thickness geometry" error when trying to use the Wrap tool to create text on a tire.
What's odd is it did it successfully on another part of the same surface.
The error:
...and the successful feature on the same surface at 180deg:
Issue #2: It won't let me do all the text in 1 Wrap command. I get this rebuild error:
It could be the curves within some of the letters. Either try a different font or remove one letter at a time to find the offending one. Then you could dissolve the text into sketch entities and make a minor change to remove the issue if you need to keep that font.
