While designing a Impeller, I'm adding tabs and slots in the assembly where the blades have to be welded to the discs. I've inserted one of 8 blades, added the tabs and slots and created a circular component pattern. The tabs appear on all 8 blades, but the slots only appear on the discs where i've inserted the first / original blade. How do i make them appear with every blade on the disc.
Thanks.
I can't remember but does it allow you to add additional faces to the tab without giving errors? If it doesn't, unless there is a work around, I don't think you can.
I think I've run into this and never found a work around, that clearly doesn't mean that one doesn't exist though.
If I recall correctly tabs, unlike features, are dependent on the mating part. It pulls faces from that part and that face is unique. So when you array one part it only thinks its tabbed with that one face. Again unless you can add the other faces I don't think arraying tabs works.
