Revision Table Row Height Issue
Question asked by K. Nezumi on Jan 27, 2021
Latest reply on Jan 28, 2021 by K. Nezumi
Hi.
I'm new to SW but not to CAD. I'm using SW2021.
I am working on a template with a lot of general tables. They are all set up with a row height of 3mm. I also have a manual revision table with the same row height. I would like to replace that manual revision table with a dedicated revision table due to the added functionality. Unfortunately, a revision table does not accept a row height less than 4.33 mm. I realize that this might be due to the wrapping of the zones but I still need a revision table with a row height of 3mm.
Is there a way to tweak this behavior? As it is, it doesn't make much sense. The user should be given the possibility to change the row height to a desired height without having to deal with a minimum size that is set in stone (at least that's how it seems).
Thank you for your help.
