I've attached an image of a symbol that appears next to a sketch in the feature tree of my part. This sketch references a master file. I am unable to edit the sketch. Does anyone have any information on this symbol? Thank you
Hi All,
I've finally gotten to the bottom of this one. As Matt mentioned, this is the 'make reference sketch' function. however, my issue was that this was appearing even when i didn't turn it on, and i had no way of turning it off. the reason is that i had a master file inserted in the part, and i created a feature that referenced the master. instead of creating a sketch that referenced the sketch in the master, i created the feature directly from the sketch in the master. since you cant edit the master sketch in the part, the sketch has this 'no symbol' next to it.
thanks for the reply, Matt.
It's called "Make Reference Sketch". You can turn it off.
