I am trying to add angular dimension between a center mark and an inclined edge. But i am unable to place dimension. Is there any other method to do same.
You are trying to do this via the API? Is it possible to create such a dimension manually at all? If not, I would add a centerline first. I would not be surprised if this is not possible at all because the center mark does not count as an edge that can be referenced.
