Is it possible to have a default / initial value assigned to the List type property in custom property tab WITHOUT changing the start part template?
I seem to only able to assign a default value to property that use Textbox but not List...
Example Scenario:
1. The Start Part / Asm template is blank without the custom property
2. User open Custom Property Tab and click Apply without changing the default value in the List
→ User only need to change the List value if they wan a non-default value.
I understand the most easiest way is to change the Start Part template, but i am just trying my luck here .
Thanks.
bump as issue still not resolved
