need help to make solid imprint of inner shape. basically its a pentagon compilation from flat plates. i want to weld those together and for that i need to make a mold to i can align plates properly. I was able to design part but now im trying to figure out easiest way to make solid so i can 3d print it and place parts on it for welding
Welding jig woudl be like kinda a crown like from inner parts form here...
Any ideas?
Worst case i can just design shape based on and angles
One way would be to place a sphere as a separate part (i.e. assembly) and use the interior planes to cut off what you don't need.
Easier way would be to create a solid using the dimensions of your inside surfaces.
