I have a PDM add-in that performs some activities when a document is released. To implement this, I add a hook using:
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PostState)
Then, in the OnCmd function, I check for the correct command type and destination state, then execute the desired code.
Now I want the same add-in to perform some activities when a file is added to the vault using a template (i.e. using a template file with a template card). I tried to add this hook:
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PostAdd)
But OnCmd was not called. So I tried all these other hooks as well:
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PreAdd)
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PreCopy)
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PostCopy)
poCmdMgr.AddHook(eCmdType:=EdmCmdType.EdmCmd_PostUnlock)
And the only hook that calls OnCmd is EdmCmd_PostUnlock. I don't want my code running on every file check-in, so this is not ideal. I really want to be notified when the file is added via the template... How can I do this? Why does it seem like the hooks aren't working for template adds?
Hi Nicoli,
I see what you are trying to do but this is going to be difficult. Could you use the RunEx Method of IEdmTemplate53? It returns all files and folders created by the template that ran.
Tim
Believe in The Q!
