Hallo!
I have e particular question. I didn't find help on the web.
I have a part with some configurations (Part_01).
Now I insert this part into a new part (Part_02).
I need the VBA code to extract the name of active configuration of Part_01 used in Part_02.
I know, and it works, the code to extract the name of active configuration of a part into an assembly.
Dim swComp As Component2
'strtemp1 is the correct string to select the part into assembly
bool = Modello.Extension.SelectByID2(strtemp1, "COMPONENT", 0, 0, 0, False, 0, Nothing, 0)
Set swComp = swSelMgr.GetSelectedObject6(1, -1)
ComboBox1.Text = swComp.ReferencedConfiguration
I was hoping the code would look similar when working on a body with configurations, but no!
Dim swCompFeature As Feature
'strtemp1 is the correct string to select the body into part
bool = Modello.Extension.SelectByID2(strtemp1, "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
Set swCompFeature = swSelMgr.GetSelectedObject6(1, -1)
ComboBox1.Text = swCompFeature.ReferencedConfiguration
The last line of the code is incorrect. Probably the "ReferencedConfiguration" is not usable whit a BODYFEATURE.
I thank those who can help me!
Marco
This method came to mind. It'll require some array manipulation and checking to make sure you have the data applying to your insert part feature.
2017 SOLIDWORKS API Help - ListExternalFileReferences Method (IModelDocExtension)
