Hello
Is there a method to create batches of 10,20 or 30 empty drawings within a folder?
There is a counter which increments the drawing number for each new drawing created.
Alternatively create multiple copies of the last drawing so a selection of title block box contents are copied onto the next 10 or 20 drawings?
The next wish would to select multiple drawings and apply the same property to a title block box - currently this type of edit is done a file at a time.
Regards
Andrew
Hi Andrew,
The answer to this will probably depend on whether you are using PDM Standard or Professional? I assume Pro as you mentioned Serial Numbers incrementing. PDM Professional has a 'macro' engine called Dispatch, that can be used to copy files and update Variables on 'checked out' files.
Cheers
Wayne Marshall
Solid Solutions Management Ltd (UK)
