I made a sketch of a circle and used offset entities to make another curve...then used extrude boss/base, and the body looks super warped!
Why is this happening?
See attached pictures.
Any input appreciated,
Thanks!
Adding to Paul's answer.
If you require the better definition all the time it is worth changing it in the templates you use otherwise every time you create a new model it will default back.
