Hi everybody,
Can anyone help me with the following situation?
I have a part A, an extrusion profile, which has its own article no./drawing/revision/description etc. I am making a derived part B of said part A, which is milled down from the situation in part A.
Is it possible to get the article no. and revision and/or description of part A into the material field of part B either through the transfer of custom properties or through a PDM construction? So far I can only get the actual material of part A to go to part B.
Thanks!
Assuming you're doing an Insert-->Part function.... So I'll be wrong.
When you insert the part, try these options. It links back to the original part. I think you can unlink them if necessary.
