I don't understand the tree of projects and stuff works in the top left of the VBA editor window.
It appears that I am accidentally linking my macros in some way... and I don't understand how or why it does this, and what you are supposed to do - because I'm obviously not doing it right!
I edit a macro and I have one set of stuff under a bold heading here.
I open a second macro for editing. I don't get a new instance of a separate VBA editor, I get a second tree of stuff I don't understand the workings of, in this window. I can swap between the two macros and edit them.
What I cant seem to do is save and close just one of them, or save just one of them to a new *. swp name
I am obviously missing some basic fundamental understanding here...
I may have inadvertently linked more than one macro SWP file here, perhaps into a single project? how do projects relate to separate swp files? nothing I can find explains that...
To my dismay/horror I find opening some of my swp files for editing from a new session, and I have several trees of stuff in this window, and I can open different windows of completely different code that is nothing to do with what I'm doing and I though was contained in totally unrelated swp files... I opened one swp file. why is code from the swp file I opened last month showing? I fear I have destroyed one of my working macro swp files accidentally when it might have been editable without me intentionally opening it.
I can find no explanation of how this tree structure works, and how it relates to separate swp files, how to purge it of the stuff I don't want there? if I have opened several macros swp files in this window, how to save and close one without affecting the others.
Has anyone got a link to a simple (from zero knowledge of vba) explanation of how this window (and the other windows) work? and how they relate to separate swp macro files?
You can correlate the macro editor to SOLIDWORKS. Like in SW, you can open several files and they appear in same session and not in different SW sessions/instances. Similar is the case when you open macros.
You can activate the macro you want to make changes to and then click on save button to save the changes. And to close any particular macro (in case you have several open), simple click this close button or right side.
