How can i get the volume of a cavity ?
Make another part and subtract your part from that part leaving you with your cavity and then look at the mass properties.
OK its worked whit a intersect fonction ! T-Y all but this method won't work in a assy.
Etienne Bouffard wrote: OK its worked whit a intersect fonction ! T-Y all but this method won't work in a assy.
Save the assembly as a part. Rinse and repeat.
