I'm getting error in checking out and checking in any file. Any idea what am I doing wrong with this CheckOut functions?
Any file that I try to check-in or check-out fails. Error message is something like: "You don't have permission to perform this action."
I have enough permissions(Admin) and file is in correct checked in / out state.
Imports EPDM.Interop.epdm
Public Class Form1
Dim filename As String = "Filename.SLDPRT"
Dim VaultName As String = "VAULTNAME"
Dim vault1 As IEdmVault20 = New EdmVault5()
Private Sub Form1_Load(sender As Object, e As EventArgs) Handles MyBase.Load
LogIn(1)
Dim searchresult As IEdmSearchResult5
searchresult = Searchfile(filename)
CheckOut(searchresult)
CheckIn(searchresult)
Function LogIn(autologin As Integer)
If Not vault1.IsLoggedIn Then
vault1.LoginAuto(VaultName, Me.Handle.ToInt32())
Return 1
End Function
Function Searchfile(filename2 As String)
Dim Search As IEdmSearch8
Search = vault1.CreateUtility(EdmUtility.EdmUtil_Search)
Search.FileName = filename
Dim Result As IEdmSearchResult5
Dim i As Integer = 0
Result = Search.GetFirstResult
Return Result
End Function
Function CheckOut(searchresults As IEdmSearchResult5)
Dim afile As IEdmFile16
afile = vault1.GetFileFromPath(searchresults.Path)
afile.LockFile(searchresults.ID, Me.Handle.ToInt32(), CInt(EdmLockFlag.EdmLock_Simple))
Return 1
End Function
Function CheckIn(searchresults As IEdmSearchResult5)
afile.UnlockFile(searchresults.ID, Me.Handle.ToInt32(), CInt(EdmLockFlag.EdmLock_Simple))
Return 1
End Function
End Class
I think the searchresults.ID is the file ID and you need the Parent Folder ID. try:
afile.LockFile(searchresults.ParentFolderID, Me.Handle.ToInt32(), CInt(EdmLockFlag.EdmLock_Simple))
