Marco Ton
Mass unit differently from document settings
Discussion created by Marco Ton on Jan 19, 2021
Latest reply on Jan 19, 2021 by Marco Ton
I have a drawing from an assembly with a BOM list where the mass should be in grams. Since the mass should be in grams the document settings is in MMGS. I want the total mass of the assembly displayed in kg's. You can view the properties with $PRPVIEW:"mass" however this is in the units specified by the documents settings. Is there a way to put the propertie locally in grams or is a formula within the note possible?. I don't like a formula in the assembly model to make a property which devide the mass by 1000.
