every time when i try to flatten a cone it doesn't work... i make the sketch very simple to use edge flange so it is already a sheet metal part, but when i press the flatten feuture it collapses into an rectangle
Don't worry, it's easy to fix.
Just edit the Swept Flange Feature. You'll find a possibility to select the fixed face for the flat pattern there. Choose the long straight edge. This is what i did in my example (from the other thread).
