I am not an expert at simulations but understand somewhat of how to do things.
I'm having issues with my simulations as I have never done an assembly like this before and I keep getting errors and would appreciate help from people to give proper results.
If I use bonded contact I get somewhat decent results, but I want no penetration.
Scenario: I am rotating (torque) a shaft in the middle hole clockwise, which will cause the jaws on the side brackets to create most of the force on the mount/jaw contact. I want to see if the mount will bend due to this force.
I have tried running lots of different simulations with "soft spring models" and different contact scenarios (currently running surface to surface) and like the results from bonded contact but I don't think "bonded contact" is appropriate for this application.
I have run two different cases (one with a bench top and one without) with both giving different results and being too high. I'd expect stresses to be around 500MPa or less, not 5000+ MPa. The benched case has given good results of roughly 250MPa except for the singularity but I wanted to do a simulation without the bench.
*When I iso-clip, I can see there is no stress on the force which there should be, indicating this simulation is wrong?
Also, is there a way to remove the singularity max value from my results and find the next real max (otherwise I'll continue to ISO clip).
I would appreciate as much help as possible as I have been stuck for a while.
Hard to tell without better pictures and or models, but here's a guess.
It looks to me like you have an "L" gib in there that you want to see if it will bend when the torque is applied to the square area.
If this is the case you are correct that "Bonded" is the incorrect choice as this will act as if the "L" gib is essentially the same part as the rail it is sliding on, in other words it is one big piece.
What you want, going from memory and I'm not an expert either, is to set a special contact set for the "L" gibs surfaces to the rail it is sliding on. You will set that to "No penetration" and there are other options like "Node to Node" etc etc. I'd look up those options and see which one makes the most sense to use.
Once you set up those contact sets you should see stress at the contact points between the "L" gib and rail.
As to why you're seeing 5000mps instead of 500 mpa. Could be all sorts of reason more than likely all of them specious and caused by sharp corners, to large a mesh etc. You'd have to hunt down the reasons for the high numbers and fix them as needed.
If that doesn't help, post your models and let some of the more expert people take a look at them :-)
