Hi, I've been trying to cut using a ruled surface as my tool but keep getting errors saying "operation failed due to geometric condition." I've tried both cut with surface and the split tool. I'm modeling a bicycle frame to be laser cut and need edges that allow me to put a bead on them. It works for one side but not the other and the order doesn't matter. Any guidance would be much appreciated.
That's a zero thickness error, because your ruled surface is essentially tangent to the solid face at the bottom of the saddle, there. That's why the Move Face works - it removes the tangency, and why the Replace Face works - because it ignores the solid face.
Another thing you can do to avoid the zero thickness error is to use the Tapered To Vector option in the Ruled surface, to angle the ruled surface slightly into the solid. The taper angle has to be 0-90, so make it say 87. You may have to fiddle with both the Reverse Direction and Alternate Side controls to get it to go to the outside and into the material at the same time. Confusing controls.
