whenever I open a new part my custom mass/sections properties change back into mm instead of staying in inches im using solid works professional 2021
See this blog post. It will answer your question and point you in the right direction: Why aren't the changes I made at Tools > Options > Document Properties saved when I start a new Part?
Hi Lucas,
When you start a new part, change the units, then save it as a part template (*.prtdot) then use that template when creating new parts.
