So I'm trying to create a reference plane that is offset in both angle/orientation AND distance from any of the three planes at the origin.
Using SW 2019, it doesn't appear that this is an option. Am I mistaken, or can you only choose one offset type, either just angle or just distance?
My recommendation would be to make a sketch(es) with construction geometry to orient the plane the way you want it if you really need a plane. However, in a lot of cases I've encountered, extra planes can be avoided with use of faces and ordinate planes as sketch planes.
