The title says it all.
PhotoView 360 doesn't save images without reporting ANY problem (e.g., "access denied", "disk is full", or "you need special rights to save to this location"). It just makes impression everything's fine and the rendered image can be found at the expected location.
No problems when saving the same image to local hard drive. It would not be a problem with one image, but when you need to save dozens of them, it becomes a noticeable obstacle to a productive work.
If anyone had the same problem and found a solution, please, share.
Thanks in advance.
