If I am exporting a SW drawing file as a PDF, it automatically crops out anything outside of the sheet view, but when I try to export a DWG, it includes these things and shows them off screen. How can I get a DWG that is just cropped to the sheet size like it does with PDFs? I went through the options and tried both "Export active sheet only" and "Export all drawing sheets to paper space," neither worked. In the sample below I show what the SW drawing file, the exported PDF, and the exported DWG files look like.
Hide the views which are outboard of the title block border prior to save as DWG:
After the save as, click Undo to restore the hidden views.
Kevin
