I have made a hole feature using the Advanced Hole feature. It consists of a .375Ø (thread)with a drill point, second hole was a .332Ø (tap drill) then a .281Ø hole 4" deep. All the hole selections were selected with a drill point. They preview as such but when I complete the feature and place the hole, the drill points on the .375Ø & .332Ø become flat bottom. The final .281Ø maintains the drill point. Not a huge issue but I like showing them with a truncated drill point. Any ideas on what's happening?
Not that I am quite sure what you are asking (a pictures says a thousand works). However, if I do understand what you are asking, this is either a bug or by design with advanced hole. Although a PITA, what I have done is add a countersink to "simulate" the drill point. Unfortunately, then it is difficult to get the advanced hole callout to work correctly (I have an SPR that may or may not be fixed now as I got in with SW2018).
