I received a part file with some revolve features in which I will be writing solidworks automation for in C# but I'm running into an issue. Each sketch of a revolve feature is created on its own plane, but none are visible in the design tree. The only visible planes are the Front, Top, and Right. If I select one of the sketches, it shows the Plane is the root of the part. Where is the plane feature? Hide/Show planes is turned on. I searched everywhere I could think of. I even wrote a macro to analyze the selected sketch and plane data and it states the plane is visible, but as the image shows, they are not. What am I missing here?
Macro
Private Sub CheckSketchPlane()
Dim swSketchPlane As SldWorks.RefPlane
Dim swSketchFeat As SldWorks.Feature
Dim swPlaneFeat As SldWorks.Feature
Dim swSketch As SldWorks.Sketch
Set swModel = swApp.ActiveDoc
Set swSketchFeat = swSelMgr.GetSelectedObject6(1, -1)
Set swSketch = swSketchFeat.GetSpecificFeature2
Set swSketchPlane = swSketch.GetReferenceEntity(longstatus)
Set swPlaneFeat = swSketchPlane
Debug.Print "Reference Entity: " & longstatus
Debug.Print "Type: " & swSelMgr.GetSelectedObjectType3(1, -1)
Debug.Print "Type Name: " & swPlaneFeat.GetTypeName2
Debug.Print "Feat Name: " & swPlaneFeat.Name
Debug.Print "Visible: " & swPlaneFeat.Visible
Immediate
Reference Entity: 4
Type: 9
Type Name: RefPlane
Feat Name: Plane10
Visible: 1
Most likely those are hidden features. Check this macro: Reveal (display or delete) all feature hidden in the SOLIDWORKS Feature Manager tree
