I have this Layout, with 5 Bodies.
I have done "Insert Into New Part", and Inserted all arcs into another part:
I need to add Triangle to Arcs (not overwrite, only add as a body to existing Part File). I can't figure out how to do it. Because, when I do Insert into new part, Solidworks overwrites the previous file instead of adding additional bodies.
This is an easy example of course, I am referring to more complicated Weldment assemblies, where drawings had been made. And in times when you need to add one or two more bodies to exported Weldment (Saved Externally with Insert Into Part) , I don't really know the way to add them, without overwriting the previous file and loosing all connections to drawings.
Please help!
P.S. in case anyone wonders, sign is from Harry Potter, Deathly Hallows.
Hi Vald
Not entirely sure why you are not making assemblies, or assemblies with virtual parts - but the way I'd go about something like this, would be by using the Insert Part feature.
I made a video showing this on your files, so this might help you or confuse you
Here it is: 2912202001 - YouTube
Tim
