See the attached image. Why do I have 2 of these menus? I am not sure it is the command manager, more like the feature tree menu? Not sure what to call it
Jacob,
That is the Feature Tree and it has had that split functionality for as far back is a can remember. The first version of Solidworks I ever used was 98 plus but I'm not sure if the first few had that.I personally hardly ever use it with one exception...if I have bunch of configs with different items suppressed/hidden/exploded i'll split it so I can activate the config in the bottom Feature Tree pane and see what is suppressed/hidden in the top tree. Oh and appearances...you can drag and drop appearances (colors) easily that way also
You can just slide that horizontal bar up or down to hide. I don't know if it's the registry settings or what. But once you move it, you should only see a single pane next time you open SW.
