I am trying to add a sheet metal jog to a part I created but the command is greyed out. I have created the part using convert to sheet metal and base/flange method and neither allow me to create the jog. the sketch bend tool is also greyed out. I know solidworks recognizes as a sheet metal feature because it allows me to create an edge flange on the same part. I am able to create an example part using the same method and add a jog no problem. My part file contains surface bodies and solid bodies, could that some how cause a problem in making the sheet metal parts?
