trying to model a Ducati Classic sport i'm having a problem constructing the tank.
I hope the bump in the middle is clear enough.
question is i need suggestion as how to create this surface with the guide lines in the reference image and an explanation as to why i'm having this problem.
any resources on improving surfacing skills are appreciated too.
thank you.
Hello Majd Al Hyer ..focus on the hard lines to get your overall shape and apply boundaries which you can control cleanly... then the challenge,.. work out the transitions, intersections/corners using fill surface with helper curves/surfaces..
