Hi everyone. Working on a thinline brace assembly for a guitar model and need your help smoothing edges out. Please see the attached .stp file and the image below.
Part Features:
1. Extruded Sketch
2. Asymmetric Chamfer at Peak
3. .06" fillet at chamfer
4. Variable Radius Fillet across entire body
Goal: Need to smooth out where the red line is, preferably within the variable radius fillet command. Peak should be completely retained (no rounding on top).
Notes: Please no surfacing.
Any suggestions on how to do this? Should I take out Step 3?
Hi everyone, thanks so much for your help and those who commented with solutions. I was able to figure out what I was doing wrong. For one, the variable fillet had tangent propagation turned on which made the solution more complicated. For two, I needed to take out the chamfer command which was also making it more complicated. It did require a bit of playing around with the radius dims (the larger 1" radius is what I needed). Here's a picture of my solution.
