Andrew Harkins
Scanning and Cacheing PDM with API efficiency questions
Discussion created by Andrew Harkins on Dec 22, 2020
Latest reply on Jan 16, 2021 by Ulf Stockburger
Hello all,
I currently have a program using the API which runs in the background to get every file and cache them locally from the PDM. This program inserts every file record into a database so a different program can use that db to do our necessary work. This scanning program is just suppose to see when a new file is on the PDM and make sure they are cached locally so we can retrieve them as necessary. The program runs and it is currently taking 6 hours! Which is a ridiculously long amount of time. Does anyone know of a way to do this and make it much faster? The part of the program that takes 3/4ths of the time is the caching files from PDM. I have tried multiple different flags (EdmGetCmdFlags). This has seemed to be the best 1 that works and caches the files to the server.
Egcf_IncludeAutoCacheFiles 2048 = Selects the Check Out dialog box Get checkbox for the latest version if the referenced file is not in the local cache
Here is my caching file method
filePathsNcount = new Tuple<List<string>, int>(PDMfilePaths, PDMfileCount);
UpdateLocalCache(edmVault5, filePathsNcount);
private void UpdateLocalCache(EdmVault5 vault5, Tuple<List<string>, int> filePaths)
            try
                if (filePaths != null)
                    IEdmBatchGet pdmBatchGetUtil;
                    pdmBatchGetUtil = (IEdmBatchGet)vault5.CreateUtility(EdmUtility.EdmUtil_BatchGet);
                    EdmSelItem[] pdmSelItems;
                    pdmSelItems = new EdmSelItem[filePaths.Item2];
                    for (int i = 0; i <= filePaths.Item2 - 2; i++)
                        string filePath = filePaths.Item1[i];
                        IEdmFile5 pdmFile;
                        IEdmFolder5 pdmFolder;
                        pdmFile = vault5.GetFileFromPath(filePath, out pdmFolder);
                        pdmSelItems[i].mlDocID = pdmFile.ID;
                        pdmSelItems[i].mlProjID = pdmFolder.ID;
                    pdmBatchGetUtil.AddSelection(vault5, ref pdmSelItems);
                    pdmBatchGetUtil.CreateTree(0, 2048);
                    pdmBatchGetUtil.GetFiles(0);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
