Why is this dimension in a rectangle? What does it represent?
A typical dimension is controlled by the default tolerance box. A Basic dimension is exempt from the defaults. It is used as a "theoretically perfect" dimension and tolerances are specified using a geometric tolerance box that defines circularity, flatness, etc. Look up GD&T for a better-worded explanation.
It's a Basic dimension. You should see a GD&T tolerance box close by that defines the allowable limits.
