Hi everyone, I'm having problems in visualize with assembly components displaying in this semi-transparent-almost woven look. For example in the below image the faceplate is not supposed to be transparent.
I checked the usual culprits
the part has a plastic material with opacity set to zero
changing the material does not fix the issue.
I've checked for duplicate bodies in close proximity.
What's interesting is that if I insert the part by itself into the visualize scene it looks perfectly normal
It only does this when I attach an assembly and as you can see in the above image, not all assembly components do this.
I've tried forcing a rebuild on the assembly, saving it and re-importing it.
I'm not sure what I can do here. Any help would be hot.
John
(solidworks 2020 SP5.0/ Solidworks Visualize 2020/2021)
SOLIDWORKS Rx Diagnostics Report
Hi John,
Do a body check in SW to make sure there are no topological errors. I've seen this before when the part was corrupt in SW.
Mark
