If I use the GetEntities() method on an IRenderMaterials object, I am trying to figure out how I can determine the types of the objects that are in the array returned by GetEntities().
If I use the code (VBA) below:
Dim swDoc As SldWorks.ModelDoc2
Set swDoc = swApp.ActiveDoc
Dim renderMaterials As Variant
renderMaterials = swDoc.Extension.GetRenderMaterials2(swDisplayStateOpts_e.swThisDisplayState, Nothing)
Dim material As SldWorks.IRenderMaterial
Set material = renderMaterials(0)
Dim entities As Variant
entities = material.GetEntities()
How do I determine the types of these entities (stored in the "entities" array in the code snippet above)?
For example some of the entities are features and I can set them to IFeature variables, or are bodies and I can set them to IBody2 variables, are components and set to IComponents2, etc....
My ultimate goal is to organize the appearances similar to the how they are presented in the Appearances Pane.
Josh Milam
Try casting each entity to IEntity object and check the entity type using IEntity::GetType
