Macro to export to various formats.
allow export assembly, parts.
Allows you to export selected parts in assemblies.
It allows exporting with the autocad coordinate system.
It allows exporting with a coordinate system of your choice.
Allows you to export all settings.
Allows you to choose the recording location, or record at the location of the original file where you also allow to create a folder to record inside it.
Allow to save with the file name, name of a custom property, or name of your choice.
It allows to export with the configuration name before or after the name, and to choose the separator between the names.
This macro is in Portuguese (PT-PT)
Possibility of translation.
Closed code.
For more information:
maladinoo@gmail.com
Attach the most current version and already translated into English.
There may be some translation errors.
I hope you put it to good use..
