Hey everyone!
Is there a way in Solidworks 2017 to explode a multi-body part in an exploded view of an assembly?
I cannot use the "reuse subassembly explode" button since it is a part, not an assembly. And also I found a solution but it only works in solidworks 2020 where there is a "from part" button under options but it is not present in solidworks 2017.
That feature wasn't available in earlier versions, as you've found. As far as I know the best option for you will be to create a new configuration and use the "Move/Copy Bodies" function to move the bodies as desired.
