The XY plot I got has a vertical axis in Pa and horizontal in meters. I want the vertical to be in dynes/cm2 and the horizontal in cm. How do I change those units?
I think you can't directly change the units shown on the axis.
But, what you can do is :
- Either change the unit of your project, it will affect the units on the axis on your graph instantly
- Or you can also write directly at the highest value on the axis by left clicking on it, the value with the unit you want, it will convert what you've written with the unit shown on the axis.
Then you can do the same for the x axis.
The first solution is probably better IMO.
