It is possible to move, rotate, mirror the derived sketch.
Can I scale derived scketch ?
-Yes,
-Yes,
-Yes with Tools/Sketch Tools/Modify/Right Click Black Dot (if Black Dots show as intended) before creating any children.
-No but a surface or a solid not merged can be scaled individually. Combine the scaled solid afterwards if merging is needed.
first part with 'yes' takes time to comprehend, with second part all clear
The aim was to do some sketch in other part-2 and insert that sketch (bi inserting part-2) in differents parts.
By the way in "Inventor" it is possible to choose what sketch you want insert. Solid inserts all sketches, when you insert part. It slightly disorientates.
no, that isn't possible. Maybe you can use a Block instead?!
