I have recently been working a lot with 7 gauge steel parts but they are quite small for that size material. Many features that work well in the models come out deformed in real life after being bent. Is there a way to have solidworks show these possible deformities before I release the parts to be manufactured?
Thanks!
Showing this deformity seems to not have a lot of value. You could determine a formula to indicate distortion and create a sensor built into a "start part" to warn you. If I remember correctly the rule of thumb we used at a previous employer was minimum 8x material thickness from edge of hole to centerline of bend. I do think this depends on the bottom die opening size however.
Might not be what you were looking for, but thought I'd mention the possibility.
