I'm having a very frustrating issue appear seemingly out of nowhere.
I have a 1.375 extruded square part.
I create a legacy counterbore with the thru-all option.
Instead of creating a hole through my part, it leaves a .004 wall.
If I set my blind depth to 1.380 (greater than .004), it will create an actual hole.
This has never been an issue before, I do this virtually every day.
Thank you,
Check the second sketch for the hole in the tree - I have found that the dimension that dictates though often needs to be re-aligned. You may find it going point to point instead of line to line.
