How do I create a flat sheet pattern of a 12" round to 12x24" rectangle lofted boss base?
Thanks Kevin.
After much trial and error I discovered that a 'sheet metal' lofted boss base requires a narrow gap where the butt weld will be. A standard lofted boss base creates a continuous object without a weld joint. Also, because of the multiple small angle bends, the sheet metal bend radius needs to be set very tight or the pattern creates double bend lines.
Use a sheet metal lofted bend.
Kevin
