We have a product here that I'm looking at putting into drive works however I have several questions and hopefully would like to avoid any pitfalls. If anyone has any input on any of these I would greatly appreciate it.
The product line is tombstones. So we have several different starting shapes with multiple different sizes of those shapes.
1) with drive works how would you deal with the different shapes? Are all the different shapes, square, rectangle, hex, octagon etc in a single model with different configurations or do you create a separate model for each shape? I suspect you can do both but what is best?
2)we have been producing these products for years. Do we start with an existing Assy or should we model up a new assy that is more easily expressed in Driveworks?
3) if we create a new model can we somehow pull the old models into drive works?
4) Can you and or how do you deal with products that can't be created entirely with the rules in driveworks. CAn you go into the model and make additions/changes etc without breaking the link to Driveworks
Again thank you very much for any information.
Hi Matt Juric
I have read your questions regarding DriveWorks. I have a bit of knowledge in DriveWorksXpress and created various projects for clients.
For the first question, if a part has similar dimensions, my recommendation will be to use configuration as DriveWorksXpress allows us to change the configurations with rules. As well as use custom properties to link dimensions so that DriveWorksXpress can change the dimensions and it will be easy for you to link with SW drawing as well.
There will be no issue If your requirements are satisfying by using existing assemblies. But take backup before starting the project for DriveWorksXpress.
Every time you run the DriveWorksXpress, software will automatically create new models with given parameters. So new models are not linked with your master model. You can definitely change or update any design after using DriveWorksXpress.
I hope this helps.
Thanks.
Ujjval Chavda - CSWE
