I would like to make a physical model of this stool out of balsa wood. To do this, I will need a template of every single different 'layer' that makes up this stool. Is there a way to do this?
Possibly essential information needed to answer this question:
-The stool consists of one part, it is not an assembly.
-I created the main shape using a swept boss/base. Then I used the 'slice' function to create a certain amount of sketches within the swept boss/base. I extruded these sketches one by one. I finally added an extruded boss/base on the side and created a linear pattern to get the same result on the other side of the stool.
I'm not real clear on what you're trying to do. Do you want a drawing view of each piece of the stool? If yes, that's simple enough. See How can I show a single body of a multi-body Part in a Drawing?
You will likely need to create a view that's normal to the side faces of these pieces. How can I Get a Non-Standard Drawing View? should help with that.
