I'm building a motor and transmission in basic volumes and I want to build a case around everything.
Is there a way to do this all at once, like a multi-body offset surface?
I'm trying to avoid having to offset each individual body then combining the offsets.
Interesting question. Kinda like a "shrink wrap" feature, - has been requested in the past. I think Dave it depends on the particular form. If you can get all the bodies to combine into one body, the Indent feature might work for you. Otherwise, you can explore the Intersect Feature - but again depends on whether either can offset the geometries involve. Can you share anything?
