Hello SW community
I've searched on the forum for the batch print process, i've found some references, however the posts are old and require a third software to make it work.
What I ideally want is : Manually open all the drawings that I need to print and execute this tool to print them all.
Does anybody know a solution that could do that ?
Thank you in advance
Jean G.
You can use SolidWorks Task Scheduler to batch print. Have you checked that out?
