I have a simple macro that draws a circle on the right plane for me. Make that HAD a macro...
Ever since upgrading to sw2020 (from 2019) my "circle on right plane" macro has been broken. It creates a circle like it should, but on the front plane.
I can manually edit the sketch plane and manually select the right plane, but then that defeats the purpose of a macro.
I've used this macro probably since 2018, possibly earlier.. its always worked before the upgrade to 2020.
Ideas?
Sketches the circle on the front plane for me in SW2018. However if I flipped these two lines of code, the circle sketch is created on the right plane. Not sure why it sketches the circle on the right plane for you.
