I commonly measure inside volume of fluid containing components with Intersect, internal bodies with the use of a gross extrusion larger than the entire design. My functional intent is to provide an estimated weight for system operating weight, by multiplying working volume by fluid density.
Is there any way that Routing can provide computation of internal Route volume, without this external workaround? We know that things can get - complicated. Even a small gap would cause intersect to fail.
It is possible to add custom property of "volume" in the part?
Like "length" so you can show and add, in BOM / cutlist.
