I tried everything to make the rib and i always get all kinds of errors if anyone can help ill appreciate it
Since it's not dimensioned, I assume the rib is at mid-length.
On a mid-length plane, create a sketch.
Convert entities on the two red lines and the blue arc.
Draw a line snapped to the right end of the converted horizontal red line and tangent to the converted arc. Trim as required.
Start an extrude and select Mid-Plane at 20mm.
Mirror to the other side (I assume).
Kevin
Hey sir what do you mean by mid-plane and mid length
Wow! Unreal.
Hi Kevin,
There is a trick when getting the moderation message:
Edit your post and add a whitespace somewhere.
Save it.
Just seconds later the post get approved most of the times.
Eddy
PS: I admire your persistence ;-)
Can you help me ?
VIA
can you send the part file pleassse !
File is attached.
Some times you have to make the rib protrude into geometry
Make a plane using the edge and the circular face of the boss.
Sketch on that plane, make sure your one sketch point is in between the circular face and the edge.Use the rib function....
Thank you so much sir it worked !
Kevin
