Greetings,
This problem is eating me a lot of time and giving me a lot a frustrations.
Very often, the 3D sketch I'm working on is going haywire like this for no apparent reason:
(and it can be way worse sometimes)
The shape I'm going for usualy looks like this:
It can happen or not, sometimes, it's ok and sometimes it's not with the same conditions.
It can happen when I'm draging a point or adding a constraint.
It feels like SW 3D sketch code is not very well tuned or I'm not working properly, I don't know...
Also, I can have another problem which gives me headaches (sory for the double question, but it is kind of the same issue). Sometimes, when I'm adding a constraint, even if the sketch is not completely and over-constrainted, I got a red and yellow devil:
I let the assembly I'm working on attached for you to play with, please note I'm working with the routing add-in with custom made components, ("Y-dusting intersection 45° unflanged - Ø24", "dusting-flange" and "dusting pipe unflanged") included in the pack-and-go document, you may have to repair some links since routing can be temperamental.
You can try to constraint the far left bottom segment to 2 inches (which should not be over constrainted if you do) and you should get the red and yellow devil
Thank you in advance for any help!
Hi Nicolas Duguay
Yes, it can act according to the drawing head when it does not dimension completely in 3d sketch.
There were times I had the second problem. I can't find the reason either.
For this drawing, I think it will be fixed when you delete the tangent command.
