Hi, I have an axisymmetric model that I would like to export a 2D cross-section of, ideally to STEP and maybe IGES as well.
I used Intersection Curve to generate curves for the cross-section in a 2D sketch. I suppressed all the parts I don't want to export. However, I can't get SolidWorks to save the sketch as STEP or IGES. I've played around with the Save As Options quite a bit, but checking "Export sketch entities" has no effect. No matter what, I either get a blank STEP file or an IGES error ("No available entities to process through IGES").
This seems like a trivial task, and I'm not very experienced with SolidWorks - so I'm guessing there's something obvious I'm missing. Does anyone have any ideas?
I attached the files in case that's helpful. I'm using SolidWorks 2019 SP5.0. The sketch I want to export is called EXPORT SKETCH.
Hello Brian... interesting.. I swear this worked... but the easiest workaround I can think of is..
Start a New part in that assembly.. edit that new part,.. start a 3DSketch... select that asm 3Dsketch.. ..and,.. Convert Select..
(close and edit assembly or stay in that part)
Saveas IGES (with the curve export option selected)
